I start a uninstallation of my product with the verbose log option. It will find that a file is in use and ask me to reboot when uninstall is finished .
If I understand it right, it will not add anything to the log after the reboot? (I'm I right?)
Is it possibe to get a log of what "msi engine" is doing after the reboot?
When does the "msi engine" execute in a normal reboot sequence? Is it before logging on to system or after?
BR Ulf
Logging after reboot?
uljo2
, Apr 25 2008 12:20
Posted 25 April 2008 - 15:46
| QUOTE (uljo2 @ 2008-04-25 11:20) |
| Hi, If I understand it right, it will not add anything to the log after the reboot? |
Correct, nothing will be added because the WI engine has completed its work right before the reboot.
| Is it possibe to get a log of what "msi engine" is doing after the reboot? |
As above, the engine's work is done once the reboot occurs. If you wanted to log what work occured between reboot and start-up, use a lightweight snapshot tool e.g. Ziff-Davis's In Control.
| When does the "msi engine" execute in a normal reboot sequence? Is it before logging on to system or after? |
That depends on how your MSIs are deployed. If via Group Policy, SMS, Radia or the like, per-machine installs occur once the machine can be seen on the network. Per-user installs will, by definition, not take place until a user logs on to the domain.
Edited by VBScab, 25 April 2008 - 15:49.
Posted 25 April 2008 - 16:54
Thanks for help.
As above, the engine's work is done once the reboot occurs. |
Is it some sort of standard windows functions that do the pending removal of files after reboot and not the msi-engine?
That depends on how your MSIs are deployed. If via Group Policy, SMS, Radia or the like, per-machine installs occur once the machine can be seen on the network. Per-user installs will, by definition, not take place until a user logs on to the domain. |
Ok, it is a stand alone msi (exe in my case actually) that i execute on my computer, then reboot.
When l log on there is autostart in registry "CurrentVersion\Run" that executes an application. Can I be sure that this one executes after the scheduled removal? (There is a chance that the file is locked by the autostarted program when it is about to be removed)
/Ulf
Posted 25 April 2008 - 17:03
| QUOTE (uljo2 @ 2008-04-25 15:54) |
| Is it some sort of standard windows functions that do the pending removal of files after reboot and not the msi-engine? Ok, it is a stand alone msi (exe in my case actually) that i execute on my computer, then reboot. When l log on there is autostart in registry "CurrentVersion\Run" that executes an application. Can I be sure that this one executes after the scheduled removal? (There is a chance that the file is locked by the autostarted program when it is about to be removed) /Ulf |
Yes, it's the PendingFileRename operation.
I'm not sure what you mean in your reply (I appreciate that English isn't your first language, BTW) so let me try and work it out.
I *think* what you are asking is if there's a means by which you can see if a file is locked by a process and, if so, to kill that process in order to unlock, thus avoiding the reboot. There's no way I can think of to test for locked files but you could simply test for the process being executed using a WMI-based script. If the process *is* running, you can either kill it programmatically (again, using a WMI method) or prompt the user to close the application.
There are many, many examples of WMI process-handling scripts around.
Posted 25 April 2008 - 17:35
I think that "peding rename operations" are executed before RunOnce but I'm not sure. You would have to double check the MSDN documentation.
