Hi All
In an effort to stop a property containing a password being displayed in the logs. I have tried creating a property 'MsiHiddenProperties' and adding the name of the property to be hidden to it. (This what I thought the MSI means)
But its not working, any ideas?
Phil
Stopping password property being written to logs
phila
, Apr 19 2004 07:23
Posted 19 April 2004 - 09:11
I think this is a known bug.
Posted 19 April 2004 - 12:19
I also had the problem to prevent passwords stored in properties to be written to the logfile. For me it works without any problems if I:
1) use Windows Installer version 2.0 (1.x didn't support the MsiHiddenProperties property)
2) checked at minimum two times that upper/lowercase of the properties listed in the MsiHiddenProperties property are exactly as the properties to be hidden
3) another problem arises from using properties in the Target column of the CustomAction table. You have to set msidbCustomActionTypeHideTarget flag in the Custom Action type column of the CustomAction table to prevent the value to be put to the logfile (add a value of 0x2000 (decimal 8192) to your CA type).
Search for "How do I prevent confidential information from being written into the log file" in the Windows Installer SDK documentation for further info.
h.teichert-ott
Posted 20 April 2004 - 03:40
The other issue I had (which probably doesn't belong in this forum) is that Installshield Dev 8 won't let you add the msidbCustomActionTypeHideTarget flag to the custom action type via the direct editor, so I altered it via Orca which worked.
Posted 26 April 2004 - 13:52
In MsiHiddenProperties the properties to be hidden have to be separated by ";"s. Make sure that there are no spaces somewhere in the list:
Good: Property1;Property2;PROP3
Bad: Property1; Property2 ;PROP3
h.teichert-ott
