All,
I hope all is well with everyone.
I have been charged with installing a "virtual" network device for my client as part of a VPN project.
The virtual adapter is installed manually by using Control Panel -> Add Hardware wizard and seems to work fine that way in Vista.
You cannot install by right-clicking and selecting Install, this doesn't work that way.
I have gone through the hell of finding out the hard way that you need DIFx 2.1 and not 2.0, so, I can now install the drivers without getting a rollback with error 0xE000020B in my MSI logs.
(by the way, I will post a message outlining this in the near future to save others this pain ...)
My problem now is, although the driver seems to install fine, when I look in Device Manager, the driver does not show up under Network Adapters like it does when I install via Control Panel -> Add Hardware.
Does anyone know a place with some useful information about this sort of thing, or does anyone here have any knowledge of driver installs?
Any help would be greatly appreciated.
Mike
Vista Device Driver Installs
mpento
, Oct 26 2007 20:48
Posted 29 October 2007 - 10:11
DIFx does not support the installation of such virtual devices by default.
If you want to use DIFx to install the device a devnode to the device must be created first (programmatically). To create a devnode take a look at the devcon source sample of the latest WinDDK.
You could also write your own device install .dll or .exe to install the device. Or simply use the devcon tool.
-Nick
-Nick
Posted 30 October 2007 - 13:08
Hi Nick,
I will look into the WDK and see what is available. Thanks very much for the help.
Mike
Mike
