I have basic msi installer.For installation of this required admin privileges.I also set condition for this in my msi.
But i face a problem.
I have a window 7 64 bit machine and i also have admin privileges.If i run my msi "as administrative" then it will install successfully and run my services .
But if run my msi on single click then it shows some problem some time and if msi installed then service is not installed.
So how can i restrict single click only option is right click and run as administrator.
i got it for Setup.exe for this one change setting Required Execution Level - Use this setting in the Releases mode to adminsistrator but this one is worked with "setup.exe".
i want same setting in ".msi" option also.
Please suggest any solution.
Edited by sanjeevbishnoi, 27 November 2013 - 08:12.
