Edited by YaI, 22 February 2007 - 06:35.
Lock files
YaI
, Feb 22 2007 06:35
Posted 22 February 2007 - 06:35
How do I lock a file in a basic MSI project? An error message should pop up if the file is use during uninstallation. How do i do this?
Posted 22 February 2007 - 14:07
The file should be marked for deletion and removed at the next reboot even if it is in use I believe. Still, you could write an Installscript or another form of script and have it check the status of the file and trigger an appropriate message. Please remember that there are 4 different UI levels in MSI - don't create a message that pops up when the setup is run silently.
