Hi, there,
Please do me a favour to answer my question.
My problem is a MSI Installation used WiX contains DIFxApp. My code is:
<Directory Id='TARGETDIR' Name='SourceDir'>
<Directory Id='SystemFolder' Name='System32'>
<Directory Id='INSTALLDIR' Name='Drivers'>
<Component Id='DRIVER1'
Guid='B3E6DDE1-6153-4155-9861-853FA4419948' DriverForceInstall="no"
DriverSequence="0">
<File Id='DRIVER1INF' Name='DRIVER1.INF' DiskId='1'
Source='DRIVER\DRIVER1.INF' Vital='yes'></File>
<File Id='DRIVER1CAT' Name='DRIVER1.CAT' DiskId='1'
Source='DRIVER\DRIVER1.CAT' Vital='yes'></File>
<File Id='DRIVER1SYS' Name='DRIVER1.SYS' DiskId='1'
Source='DRIVER\DRIVER1.SYS' Vital='yes'></File>
</Component>
<Component Id='DRIVER2'
Guid='392ED8CF-EDA9-40ff-BA02-A2D4312EFDBC' DriverForceInstall="no"
DriverSequence="1">
<File Id='DRIVER2INF' Name='DRIVER2.INF' DiskId='1'
Source='DRIVER\DRIVER2.INF' Vital='yes'></File>
<File Id='DRIVER2CAT' Name='DRIVER2.CAT' DiskId='1'
Source='DRIVER\DRIVER2.CAT' Vital='yes'></File>
<File Id='DRIVER2SYS' Name='DRIVER2.SYS' DiskId='1'
Source='DRIVER\DRIVER2.SYS' Vital='yes'></File>
</Component>
</Directory>
</Directory>
</Directory>
When I setup a single driver, it would be successful. I could not install
two or more drivers in one installation. See following error picture.
The Error Code is:
DIFXAPP: InstallDriverPackages
DIFXAPP: 'CustomActionData' property 'DIFxApp Version' is 2.01.
DIFXAPP: 'CustomActionData' property 'UI Level' is 5.
DIFXAPP: 'CustomActionData' property 'componentId' is
{B3E6DDE1-6153-4155-9861-853FA4419948}.
DIFXAPP: 'CustomActionData' property 'componentPath' is
C:\WINDOWS\system32\Drivers\.
DIFXAPP: 'CustomActionData' property 'flags' is 0xA.
DIFXAPP: 'CustomActionData' property 'installState' is 2.
DIFXAPP: 'CustomActionData' property 'ProductName' is MyTest 1.0.
DIFXAPP: 'CustomActionData' property 'ManufacturerName' is MyTest
DIFXAPP: ERROR more than one driver package found in
DIFXAPP: InstallDriverPackages failed with error 0xD
Could you give me a piece of advice? Thanks a lot.
I also use InstallShield 12 Evaluation, the same thing happened.
Dose anyone know how to fix this problem?
BR,
Daniel
A problem of driver setup using DIFxApp
danielxu22
, Jul 04 2006 06:48
Posted 04 July 2006 - 09:46
I found this
http://www.eggheadca.../post583805.asp
Can it still be the case that DIFxApp won't install multiples?
Posted 04 July 2006 - 14:57
You need to install both .inf files in their own folders. Annoying but that is the only way. Eg:
Folder 'Driver1' where you install component1
Folder 'Driver2' where you install component2
After that the InstallDriverPackages action should run fine.
