Conditional Reboot
cherukus
, Jul 01 2004 16:39
Posted 01 July 2004 - 16:39
I am using Basic MSI - Installshield Developer 8.0.
I want to prompt the user to Reboot his PC after he installed MSDE & APP.
I don't want to invoke the reboot when when he uninstalled the APP and also when he re-installed the APP.
I tried setting a flag in the ScheduleReboot in the Install Execute Sequences, but seems NO effect.
Schedule Reboot
Condition : ISSCHEDULEREBOOT Or MSDEInstalled
MSDEInstalled flag is set to Yes when the user installs MSDE, if not by default it is set to NO.
Appreciate any ideas !!!
Schedule Reboot
Posted 02 July 2004 - 08:47
If the value of property MSDEInstalled is either Yes or No, then use this condition:
ISSCHEDULEREBOOT Or MSDEInstalled~="yes"
The ~ performs a case insensitive string comparison
Posted 02 July 2004 - 17:34
Unfortunately after I made this change, it is never invoking the Reboot.
I am not quite sure why it's behaving differently.
Posted 05 July 2004 - 15:39
In which sequence are you setting the MSDEInstalled property? Since it has lower case characters in its name it's a private property, its value is only available in the sequence where it was set. So if you set it in the UI sequence you cannot read it in execute sequence.
Posted 06 July 2004 - 20:13
Yep..you are right. I was not aware that it would be a private property.
How do I make this a public property so that I would be able to access the value in the Execute Sequence.
Posted 07 July 2004 - 08:51
Public properties must be in all capital letters
Posted 15 July 2004 - 04:33
Just a note: if your setup is run by a regular user with elevated rights not all public properties are sent to the execute sequence, only the properties enumerated in the SecureCustomProperties property. In other words I would add your custom property to this list:
Example: SecureCustomProperties: MYUPGRADE;MSDEINSTALLED
Info: http://msdn.microsof...es_property.asp
