How can I replace the UNINSTALL_STRING or UNINST value. I need to have a custom uninstallstring run NOT the uninstall that the .msi uses (rundll32 c:\progra~1\common~1\instal~1\engine\6\intel3~1\ctor.dll<UNINSTALL_CMD>).
Thank you
Posted 23 October 2001 - 17:08
Thank you
Posted 23 October 2001 - 18:50
Posted 24 October 2001 - 06:28
Set the following registry value "UninstallString" to your dll "rundll32.exe <arguments>" in the registry key HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{your-product-code}.
Be sure to set this too
"DisplayName" to your product name
otherwise, you might not able to see your product under Add/Remove dialog.
In your script you can access your current product code using the variable PRODUCT_CODE (or similar).
-regards
Posted 24 October 2001 - 12:26
