In InstallScript MSI 8 project, can we use Control Event table available under Direct Editor to trigger a Custom Action ?
This is my requirement :
I want a custom action to be called at the click of any Features listed in the tree, for this to happen i am giving the following entry in Control Events Table.
Dialog_ : DialogId_12052
Control_ : ControlId_1000
Event : DoAction
Argument : FeatureCheck
Condition :1
Ordering : (Blank)
Here
"FeatureCheck" is the Name of the CustomAction written in Installscript.
"DialogId_12052" is the dialog id for sdFeatureTree dialog
"ControlId_1000" is the id given for Selection tree
I am leaving the Ordering column as empty.
I am able to call a "DoAction" Event at the click of Next button in Basic MSI project by populating the details in Control Events Table
How should i achieve this in InstallScript MSI project?
Should i use scripts to do this? If yes, what is the API i should use?
Can any body help me to solve this issue?
Alamelu
Control Events Table in InstallScript MSI 8
Alamelu
, Aug 10 2005 12:45
Posted 11 August 2005 - 08:35
Im not sure about Install Script, but for plain windows installer, a control event is not published when the user clicks on a feature.
Posted 11 August 2005 - 09:52
In InstallScript MSI projects that user interface is solely controlled by the InstallScript, so the UI tables in the MSI are not in effect. In other words: no. You have to do this in script.
Posted 12 August 2005 - 06:23
Thank u so Much Luke and Stephan krueger.
If i had to do this in Script what are the functions that i should use?
Any sample code can help me so much.
Any website, ebooks or books to refer about Installscript functions?
Where can i look for more information on this?
Alamelu
Alamelu
Posted 14 August 2005 - 10:41
You can find InstallScript dialog samples at http://www.installsi...s/en/isp_ui.htm
