Hi all,
Here's another problem, at least I think its a problem....
In our previous release we had included the VC++ 2008 runtime via Merge Modules. We also have them included in the latest release.
However, post install, a repair is fired. After further investigation of the Event Log and .msi, I found that the problematic component pointed to one of the Merge Modules.
Also, from the log I got this...
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {634088A3-D67E-336D-9425-767BA6907C74} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {3C582984-7607-3E35-A337-D3D327097351} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {229E8F96-1AE0-32E6-8428-D2CBCA122740} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {CB438DD9-2B1B-32E0-9AA6-D6DA82CE9D97} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {6D321E57-3E99-3B87-BF23-2CDFF3361CB4} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {AE56AAF5-F3C0-3D4B-8859-A1E50A3E27BF} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {63E949F6-03BC-5C40-A01F-C8B3B9A1E18E} since the assembly already exists
MSI © (C8:50) [17:40:33:205]: skipping installation of assembly component: {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E} since the assembly already exists
What the heck is going on here? If it's not something I'm doing wrong, its got to be a bug, no?
Our prevous install was made with Wise so maybe the Merge Modules used with that have a higher version that what is included with install shield. ??
Any help is GREATLY APPRECIATED!
Thanks in advance!!
Merge Modules, Major Upgrade, More Problems
Superfreak3
, Mar 01 2011 03:09
Posted 01 March 2011 - 16:22
Is this a major upgrade (ProductCode changed)? Does changing the upgrade option to "install new version then remove unused files" instead of "uninstall old version then install new version" fix the problem?
