"Setup has detected that UninstallShield is in use. Please close UnInstallShield and restart Setup. Error 432."
No UninstallShield instances are running. The user should get message "To install <product>, you must have administrative rights to this machine".
When trying to run UninstallShield on W2K Adv. Server without administrative rights, the following error is given:
"Unable to locate/process internal binary resource."
Sometimes when trying to start Setup on Japanese W2K host without administrative rights, the Setup immediately shows an empty message box and exits.
Sometimes the following error occurs on the start of Setup.exe on W2K host:
"Setup.INS has become corrupted. Unable to load installation instruction. Error 704"
Needless to say that the same Setup works on non-W2K hosts.
I've already read InstallShield Support documents:
Q105007 and Q104333 but with no help.
If any of you what might cause these problems (or better yet, how can these be fixed in IS5.x) I'd really appreciate that. Please note that I can not upgrade to IS6, I MUST use IS5.1 or IS5.5.
TIA,
Torgui
