I the new Windows installer, it's possible to create a multi-instance for installing one setup several times.
I just want install in the first time (with parameter AAA), and in shortcut, i want <Program name> "AAA" and in "Add/remove panel" <Program name> "AAA" whith remove button.
And if i launch in the second time, add new parameter like BBB, and in shortcut, i want <Program name> "BBB" and in "Add/remove panel" <Program name> "BBB" whith remove button.
It's possible in Installscript pure mode but the multi-instance is not available directly in Installshield interface of i not found this.
It's really impossible or i don't have solution or option for this ?
Thank you.
Gilles
Multi-install with MSI
gcb
, Oct 05 2005 12:24
