I need to change the CMDLINE value in the table Properties, but do not know how to do this.
When I start the msi installer "Setup.msi /quiet" I want the value of CMDLINE to be changed into "/s"
This is important for a execuatble inside the msi installer wich will be executed, and must have a command line argument, in this case "/s" if you want to run the application in silent mode.
Any idea's ?
Ton.
I'm using InstallAware to create the MSI installer, and they do not support this kind of functions. I also have Miscrosoft Orca to edit the MSI database.
Edited by ton_b, 25 January 2006 - 09:18.
