Hello,
I have a guid as string like "DB087CCC-AF2C-431d-84A3-25291FF089D5", and I need to convert them in a structure like
typedef struct _GUID {
unsigned long Data1;
unsigned short Data2;
unsigned short Data3;
unsigned char Data4[ 8 ];
} GUID;
(typical Microsoft GUID structure).
In Installshield (11) I've defined a structure like:
typedef GUID
begin
LONG Data1;
SHORT Data2;
SHORT Data3;
CHAR Data4(8);
end;
Any idea how to populate the GUID defined structure from my string in Installshield 11 ?
Is there a function which is predefined, and already does this?
Thanks.
Convert string to GUID structure`
bogdan.carjac
, Mar 05 2007 17:31
Posted 05 March 2007 - 18:29
Da gibt es glaube ich nichts vordefiniertes. Am besten nimmst du die String-Funktionen (StrFind usw.)
Posted 06 March 2007 - 08:57
Thank you, I appreciate your answer, even if my German is not so good.
But I think it's not a metter of Substrings. It's more an issue of converting a GUID string into GUID structure, so what i need is an algorithm, IF Installshield doesn't have a predefined function which does something similar (as I understood from your German explanation).
And if Installshield doesn't support that... it will be my job to think about an algorithm.
Best regards,
Bogdan.
Best regards,
Bogdan.
Posted 07 March 2007 - 11:47
Hello,
I solved the problem and I used CLSIDFromString method from Ole32.dll.
I presume it's similar with what you've described. But there is a problem, and i think it's an installShield 11 problem.
The DLL's method is expecting an UNICODE string:
HRESULT CLSIDFromString(
LPOLESTR lpsz,
LPCLSID pclsid
In Installshield I placed a STRING variable, and I checked! is not working!
So STRING variable I think it is MBCS!
I checked in Installshield documentation and it says STRING type is unicode, which I think is wrong. In order to make it work I used WSTRING !
http://www.installsh...Pro7Excerpt.pdf
I guess that's interesting to know... anyway in my case I was able to call the DLL's method only with WSTRING !
Best regards,
Bogdan.
LPOLESTR lpsz,
LPCLSID pclsid
Best regards,
Bogdan.
Posted 08 March 2007 - 17:51
| QUOTE (bogdan.carjac @ 2007-03-06 09:57) |
| Thank you, I appreciate your answer, even if my German is not so good. |
Apologies for that. To much jumping between the English and the German section of this forum.
