I have a file that is deployed by the MSI, we use a product called Radia to perform nightly checks on the users desktops that performs a verify of the MSI package that is deployed and repairs the MSI if it thinks it is necessary to do so. (standard MSI stuff).
I have an ini file that gets deployed that I do not want the MSI to fix as it contains font information, colour schemes etc. The application requires this file to be installed.
Is there a way for the MSI just to deploy the file and not check that the file has changed?
Dan
Getting MSI not to check for an INI file change
dantamone
, Apr 28 2004 11:18
Posted 28 April 2004 - 15:29
If you don't want to overwrite the existing file, you can set the never overwrite bit for the component.
