I am building a DevStudio 9 Basic MSI project and I have edited all the dialogs using the dialog editor, replacing the IS logos with my own. However, when I run the setup, the very first dialog still shows the IS logo (attached).
Is there a way to replace this logo as well?
Editing dialogs
tsquared
, Apr 21 2004 21:37
Posted 22 April 2004 - 08:53
Hi tsquared,
the easiest way (kind of) replacing this bitmap is to use a splash screen bitmap. When you do this the original dialog is replaced by the splash screen and you will see only a smaller initialisation dialog.
If you don't want to use a splash screen you'll have to use a resource editor to edit the resource dll.
Hope this helps.
Regards,
Jochen
Hope this helps.
Regards,
Jochen
Posted 23 April 2004 - 03:33
You could also look into using the direct editor (Control and Dialog table) and change the bitmap though there.
