Split one large MSI into small msi
aarthi_m
aarthi_m
  • 65 posts
Posted 21 August 2008 - 13:29
Are there any tools available that split a MSI into small msi files depending on the features that I want to install.
Say, my installer gives me 5 features to install and I need only 3. Is there a way to break the MSI which has files for all 5 features into a smaller MSI which has files only for the 3 features I need?
One way I can think of is by building the features into different cabs and a light weight MSI. So, I can use only the cabs that I need and the MSI. The downside of this is I need to know which cabs correspond to which feature and choose the right ones.
I would like to know if there are any other ways.
Any help would be of great use. Thanks!
Zweitze
Zweitze
  • 522 posts
Posted 21 August 2008 - 13:52
If you use InstallShield you can include features based on build flags - you can define different builds with different flags.
I wouldn't recommend your approach though: make sure that you think through all scenarios for upgrading, patching etc.
