Hi!
This is an easy question. As Installscript is a unluckily bad designed language, I've been forced to use pointers to perform really simple actions... and now I'm stuck on the following sentence:
*pParam = ¶m;
where pParam is a pointer to an array element, and param is a struct instance.
It does not compile, as the construction does not fit the grammar... (compile time).
Does anybody know how to assign the value of a pointed variable?
Any help is appreciated.
Assign an address to a pointed variable
jefeh
, Aug 28 2008 09:28
Posted 28 August 2008 - 10:05
I've found that
| "The indirection operator cannot be used to assign a value to a memory location" |
is one of the limitations of the indirection operator...
but there must be a way to perform this operation... and the only way I can imagine is writing a C DLL... but that solution stinks!
