Hi forum,
I have an 32bit-Installation. Is there any possibility to find out if the target machine has a 64bit OS or not? I would like to add this condition to a feature. If a 64bit OS has been found one special feature should be set to "not installed".
Thank you very much,
Torben Schulz
How to find out if OS is 64bit or 32bit?
Torben
, Feb 21 2007 16:21
Posted 23 February 2007 - 14:58
You could try the VersionNT64 property.
Posted 24 February 2007 - 21:52
Hi Stefan,
Thank you very much, it workes fine.
I thought that this property isn't available as long I used my setup on a 32bit system. Building my condition always led to an error using WISE, because this property can't be verified on my development pc. But never the less, it works. :-)
Best regards,
Torben Schulz
Best regards,
Torben Schulz
