I am using ISX 3.51. After changing the bitmap on the 'Setup Complete' dialog, the 'Show Readme' checkbox is hidden behind the bitmap. If you click on it, it appears. I have seen an earlier post in this forum that says you must change the tab order to fix this. I can't do that in ISX, but I can use Orca to edit the .msi directly. Where do you set the tab order in the .msi tables?
Checkbox hidden behind bitmap
Jim S
, Oct 15 2001 14:59
Posted 15 October 2001 - 15:14
The Control Table.
Tab order is implemented with the Control_Next field. A loop is created with the names of the controls you want to include in the tab sequence. Some controls may not be included in the tab order.
Posted 18 October 2001 - 23:28
Thanks Ian.
That worked! :)
This ISX file was originally created with ISX 3.03. I noticed that a setup built entirely from scratch with ISX 3.51 did not appear to have this problem at all.
