I am trying to create a Windows Installer package using InstallShield Developer 7.0 (SP4) that will perform a minor upgrade to an existing product.
I have taken the original installer and modified the "Package Code" and "Product Version" but left the "Product Code" unchanged. I have also updated the file version numbers in the product's files.
When I perform the upgrade using the "REINSTALL=ALL" and "REINSTALLMODE=vomus" settings it appears to work fine. The new product replaces the old product and runs successfully.
The problem arises when I try to uninstall the upgraded product. At this stage, although the new MSI package has been cached (due to the "v" option of REINSTALLMODE), the old setup.rul script is still used and this fails to remove the product.
The actual point of failure occurs when a new custom action (that only exists in the new package) tries to access a new script function (which doesn't exist in the old script).
If the product is installed on a clean machine it uninstalls without any problems, it only fails when trying to uninstall after performing an upgrade.
I would be very grateful if anyone could suggest how I might force the new setup.rul script to be re-cached along with the rest of the MSI pacakge.
Thanks in advance,
Mark.
Minor upgrade - InstallScript issue
MarkBond
, Jun 21 2004 11:25
