I have created a Custom action which will call a batch file and installs OracleXe in silent mode.. But while installer is calling bat file while installing the app its not installing the oracleXe. Following is the Custom action for command line -
cmd.exe /c c:\dbinstall\DBScripts\installXE.bat
Following is the installXE.bat
C:\dbinstall\DBScripts\ OracleXE.exe /s /f1"C:\dbinstall\DBScripts\OracleXE.iss" /f2"c:\setup.log"
Attched is the snapshot where bat file not working ...
Zk
Installshield 2010 - Custom Action problem
zakirahamad
, Jun 03 2010 13:10
Posted 08 June 2010 - 08:52
Does the .bat work when called directly (not from the setup)? It looks like you have an extra space between the \ and OracleXE.exe
Also, make sure the custom action is set to run deferred in system contaxt (non-impersonate). This might be a permission issue.
