I am facing a peculiar problem of installing a network device driver in windows 2000 machine.
Please suggest the best possible way to automate the installation of the driver as a service .
kind regards
Posted 08 December 2001 - 10:41
kind regards
Posted 11 December 2001 - 19:05
Check out the service under the key:
EventSystem
Not all of these are needed but you should get the point. Might try searching for a service that has the same type...
Once the reg entries are placed, you can use launchappex and do basically this (as you would do at the cmd prompt):
net start <Your Service Name>
net stop <Your Service Name>
May need quotes around the service name (which is the description btw) and it is a little tricky to get the quotes right in the launchappex but it works. (Use \" to get a quote inside quotes in IS.)
