I am trying to create a patch file for a Windows Installer installation. I have created the .pcp file and need to create the .msp file. When I type the MsiMsp.exe command line, I get a message stating " not recognized as a valid command,program,batch file etc." from the command line prompt.
I have an updated version of the installer SDK and I know the MsiMsp.exe tool is installed on my system.
Any ideas as to what I can do to make it run properly?
MsiMsp.exe Not Recognized
twalker15
, Apr 27 2004 13:30
Posted 27 April 2004 - 15:47
Do you specify the correct path to msimsp?
Posted 27 April 2004 - 16:46
As Stefan mentioned it should just be a path problem....copy the msimsp.exe from the SDK\bin into your local directory and run the command again.
Posted 07 January 2005 - 03:18
| QUOTE (Stefan Krueger @ 2004-04-27 15:47) |
| Do you specify the correct path to msimsp? |
In my case,
MsiMsp.Exe exist in "(Platform SDK)\Samples\sysmgmt\msi\Patching" folder..
Posted 26 August 2005 - 14:48
I want to do the same think like you but I can't find the msimsp.exe tools althought I installed windows installer SDK followinf this link :
is this the link you used?
I'm under Windows XP pro
thx for help
thx for help
Posted 09 May 2009 - 10:17
Hello There,
In My case I have found msimsp.exe and run command file. but it is giving following error
Failed to Create patch. Error code : 0xC00E5198
can anybody please help me?
Thanks in advance.
Thanks in advance.
