I have developer 9 downloaded. I have tried a number of project types. I am new with developer 9 and with installshield as an app...
The agenda is that I need to install the following:
a) .net if needed
1) asp.net application (aspx, plus dll's)
2) msde database (stored procs)
3) a registration key
My question and initial notion was to use the combo (installscript and mSI) to save
time and resources.
Now I understand that it is not advisable.
I need to do lot of checking and version verfying so script code is needed but I wonder if I could use a project type (msi only) and use install script still?
My main concern is the reg key code and other areas where I feel the combo would be best - but I am afraid of the posting on this board say otherwise.
general help needed
andrasnm
, Dec 11 2003 16:52
Posted 16 December 2003 - 13:15
Even when using the "Basic MSI" project type you can use InstallScript - by inserting a custom action. Alternatively you could use VBScript or a DLL, written in C.
If fell more comfortable with a pure scripting solution you could use the "InstallScript" (not "InstallScript MSI") project type. This doesn't use any Windows Installer (MSI) at all, but is a pure script solution.
