I am using ISDev 7.02 and trying to call a function in a DLL from a Standard Project, but not sure how to do it. According to the Developer Help, I would use the functions UseDLL, CallDLLFx, and UnUseDLL. However, there is some sample code under "UseDLL" that does not call "CallDLLFx", but instead calls the DLL function directly. Any idea what is the correct way?
Installscript and DLLs
tsquared
, Jun 03 2003 22:40
Posted 04 June 2003 - 07:08
You don't use CallDLLFx. Instead you prototype your DLL function in the script, then load the DLL with UseDLL. Now you can directly call your DLL function. Finally you unload the DLL with UnUseDLL.
CallDLLFx is only for the situation where you don't know the DLL function (and therefore can't prototype it) at the time you write your script.
