I have a small issue that I guessed would not be *that* uncommon, but I could not find a useful answer on this one, so I am hoping someone here might have experienced that.
I have an installer that installs a 32 bit product (hence the Template Summary is set to "Intel"). That product is capable of running inside the "Windows on Windows 64" layer, so the installer is intended to run on a 64 bit OS as well. My installer runs well on both, but there is one nagging issue on the 64 bit OS:
As it happens, the installer needs to write registry keys and values in HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\PropertySystem\PropertyHandlers. When installing on a 32 bit OS, these keys and values end up where they're supposed to be and the Explorer picks up on the entered property handlers.
However, when running the installer on a 64 bit OS, the keys and values are entered in HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\PropertySystem\PropertyHandlers, which is not helpful at all (on the 64 bit OS explorer.exe is a 64 bit process and as such it could not care less about the contents of the Wow6432Node hierarchy...).
So what I need to find is "the correct way" to write registry keys and values in HKLM\SOFTWARE\ from a 32 bit installer in such a way that the keys do not end up in the HKLM\SOFTWARE\Wow6432Node section on a 64 bit OS. But apparently as long as the component writing the registry keys is not marked as a 64 bit component registry virtualization strikes and the keys and values are redirected into the 32 bit view of the registry. Marking the component as a 64 bit component is not an option however, because this raises an error as long as the Template Summary is "Intel". The "Disable Registry Reflection" flag is not set either, which is why I am even more surprised I have this problem in the first place.
Does anyone know a better way to achieve what I need than writing a CA that takes care about this???
Thanks in advance for any comments.
Best regards
Volker
Edited by vgimple, 04 May 2011 - 16:37.
