In OnMaintUIAfter, I am calling CreateRegistrySet("MyRegistry"). The return value is 0 (success), but the entries are not being added to the registry. Has anyone else seen this? It is occurring on 95A, 95B, 95C, and Win2k boxes. Is there a workaround other than calling RegDBCreateKeyEx() for every key?
David
CreateRegistrySet problems
dalkema
, Dec 03 2002 16:26
Posted 03 December 2002 - 18:44
I only have one registry set, so I simply call CreateRegistrySet("") under IS 6.31 to have all of them added. Never tried explicitly adding one, but I know the help file says that possible.
I'd suggest trying "" as the parameter and seeing if that at least adds something.
Posted 03 December 2002 - 22:44
Something that occured to me reading your question: You state that you make your CreateRegistrySet("MyRegistry") in OnMaintUIAfter(). Did you want to maybe call it it OnFirstUIAfter()? That way it will be run with your installation, not in maintenance mode.
Posted 03 December 2002 - 23:18
Ah, yes good point Xitch13. I read that this morning and overlooked that fact.
