Are there any 3rd party tools (not a full fledge MSI editor or packager) that can generate tab or comma delimmited reports on the contents of a MSI package? I'm looking for something that would be friendly to the user and that creates clean reports.
Generate Reports on MSI Files
jlcollie
, Nov 04 2003 21:54
Posted 05 November 2003 - 10:41
SQL. Maybe you could run queries using WiRunSQL.vbs and output to a text file.
Posted 06 November 2003 - 04:53
Orca can export selected/all tables in IDT format which is a delimited format, if you want something more readable/automated you could use my "MSIDIFF" tool that is currently bundled with me free MAKEMSI tool (http://www.labyrinth...eis/makemsi.htm).
Dennis Bareis (dbareis@No.Spam.gmail.com)
Free MSI update/creation tool (MAKEMSI):
http://users.cyberon...eis/makemsi.htm
Posted 06 November 2003 - 08:28
If what you need is a list of components in the project, I adapted a script originally created by Senior Trainer Robert Dicau from Installshield so that it exports all components into an Excel sheet. It is a VBA script. If this is of interest I can dig up the code and post it here.
Posted 06 November 2003 - 20:26
Glytzhkof
I would like to see the VBA script which exports all components to Excel.
Posted 07 November 2003 - 02:38
Const TheInstallshieldProject = "C:\BasicMSI.ism" Const TheExcelSheet = "C:\sheet.xls" Dim aComponentCollection, oneComponent, oneInstallshieldProject, TheFiles, i Dim oneExcelApp, oneExcelBook, oneExcelSheet, oneExcelRange, columnRange Set oneExcelApp = CreateObject("Excel.Application") Set oneExcelBook = oneExcelApp.Workbooks.Open(TheExcelSheet) Set oneExcelSheet = oneExcelBook.Worksheets.Add oneExcelSheet.Name = V_MAJOR & "-" & V_MINOR & "-" & V_BUILD Set oneInstallshieldProject = CreateObject ("ISWiAutomation.ISWiProject") oneInstallshieldProject.OpenProject TheInstallshieldProject Set oneExcelRange = oneExcelSheet.Cells(1,1) oneExcelRange.Value = "Component" oneExcelRange.Font.Bold = True Set oneExcelRange = oneExcelSheet.Cells(1,2) oneExcelRange.Value = "Files " oneExcelRange.Font.Bold = True Set oneExcelRange = oneExcelSheet.Cells(1,3) oneExcelRange.Value = "Destination" oneExcelRange.Font.Bold = True Set aComponentCollection = oneInstallshieldProject.ISWiComponents i = 1 For Each oneComponent In aComponentCollection ' Count lines to set correct range i = i + 1 Set oneExcelRange = oneExcelSheet.Cells(i,1) oneExcelRange.Value = CStr(oneComponent.Name) Set oneExcelRange = oneExcelSheet.Cells(i,2) Set oneFileCollection = oneComponent.ISWiFiles For Each oneFile In oneFileCollection TheFiles = TheFiles + oneFile.Name + vbLf Next oneExcelRange.Value = TheFiles TheFiles = "" Set oneExcelRange = oneExcelSheet.Cells(i,3) oneExcelRange.Value = CStr(oneComponent.Destination) Next oneExcelApp.Cells.EntireColumn.AutoFit oneInstallshieldProject.CloseProject Set oneInstallshieldProject = Nothing oneExcelBook.Save oneExcelApp.Quit Set oneExcelApp = Nothing |
