Uninstall woes
Posted 16 October 2007 - 00:38
So I have 2 questions:
First, how do I enable logging so that I can catch what is happening when I run from Add/Remove Programs?
Second, what is the difference between running the uninstaller from Add/Remove Programs and selecting Remove from Maintenance mode?
-- spdygnlz --
Posted 16 October 2007 - 08:28
- Restart the w/s or VM
- Start your installation.
- Logs appear in %SYSTEMROOT%\Temp as MSI[randon_hex_number].LOG
This is an all-or-nothing policy, meaning that every install will write a log so you'll need to clear TEMP down before and after or turn the policy off. Of course, you can set this policy with GPMC if you prefer. I can't recall the exact policy name, though. Knowing MS's penchant for double-negatives, it's probably "Don't not disable MSI logging"...
Posted 16 October 2007 - 15:39
Does it work if you click the "Modify" button in control panel, and then select the Remove option in the maintenance type dialog?
Posted 17 October 2007 - 20:42
The GPMC that you refer to intrigues me. I downloaded it, but I could only access Group Policies (imagine that from the Group Policy Management Console!), and even then, I didn't see anything that pertained to MSIs. Is there another Policy editor that you were refering to, or do I just have it all mixed up? I've always wondered what the easiest way to modify all those MSI policies was. It'd be nice if it had a UI so we could show customers how to enable certain things if need be.
I'm going to try the registry entries for now. Thanks for the tip.
Stefan,
So if the only difference is that the UI doesn't run, that seems to suggest that maybe I'm setting something in the UI that needs to be there to uninstall properly. Would you agree?
I haven't yet tried to uncheck everything using the Modify option. I assume that it would be similar to using the Remove option. The only thing about doing it that way is that we have a few hidden features that the user cannot unselect so it wouldn't get completely removed. At least a lot of the shortcuts we place would be removed. I'll try that.
Thanks you guys!
-- spdygnlz --
Posted 18 October 2007 - 08:42
| QUOTE (spdygnlz @ 2007-10-17 20:42) |
| Is there another Policy editor that you were referring to, or do I just have it all mixed up? |
No, you're not mixed up, I am! I spend most of the day in GPMC (which is why I'm building a script/app to automate the assigning of MSIs to GPOs...) and thus it was the first thing that came to mind. What you *actually* want is GPEdit.MSC.
- Browse to Local Computer Policy/Computer Configuration/Administartive Templates/Windows Components/Windows Installer/Logging
- Set to 'Enabled'
- Enter 'voicewarmup' into the Logging field
Apologies for the bum steer.
| So if the only difference is that the UI doesn't run, that seems to suggest that maybe I'm setting something in the UI that needs to be there to uninstall properly. Would you agree? |
A pound to a penny that there is a Custom Action in UI sequence which is responsible. If you're not comfortable with perusing the CA table to determine that, or the CAs have confusingly similar names, it might behove you to run both flavours of uninstall and compare the logs, now that you're "logged-up".
Edited by VBScab, 18 October 2007 - 08:47.
Posted 18 October 2007 - 16:53
| I haven't yet tried to uncheck everything using the Modify option. |
Posted 18 October 2007 - 17:18
I looked at the CAs that I have in the UI and none of them modify anything but there are some that set important properties for CAs used later on. I'm going to have to look at the code a bit more to figure out exactly which one is the culprit. (The Logging will help.)
Perhaps what I need to do is set some of them to schedule them to run in Client and Server mode and change the execution to "Execute only once".
Stephan,
I do have the maintenance welcome dialog, I just haven't tried using the Modify option on it to remove everything yet. I've used the Repair and the Remove, and even the Modify to add more features, but not to remove them.
Thanks you guys! I'll let you know what I find in the CAs.
-- spdygnlz --
Posted 18 October 2007 - 19:30
Posted 07 November 2007 - 20:13
Going about it another way, is there a way I could simulate the Add/Remove programs remove functionality from a command line? I could easily tell it to drop a log file from there.
-- spdygnlz --
Posted 08 November 2007 - 10:48
Posted 10 November 2007 - 12:33
To simulate the Add/Remove Programs behaviour you could run your install in Basic UI mode:
msiexec.exe /x {ProductCode GUID} /qb
Posted 28 November 2007 - 22:33
| To simulate the Add/Remove Programs behaviour you could run your install in Basic UI mode: msiexec.exe /x {ProductCode GUID} /qb |
That's what I ended up doing. I found the offending custom action and removed it. It works as expected now. Thanks!
-- spdygnlz --
