Hello,
For each install on a target machine, I want to add a *short* summary to an "external" log file.
For this purpose, I have written some custom actions that log the start, the successful installation, user interrupt, and abort.
For an abort, I want to include at least the relevant error number (or better some error text - Error table?) in the logfile. So I wrote (in InstallScript):
MsiGetLastErrorRecord
Matthias1967
, Aug 06 2009 07:51
Posted 06 August 2009 - 07:51
| nvBufferSize=1024; ErrRec=MsiGetLastErrorRecord(); MsiFormatRecord(hMSI,ErrRec,svErrMsg,nvBufferSize); svOutStr= "Installation of MyProduct aborted, error: "+svErrMsg; |
However, the svErrMsg remains empty.
I run this custom action by a control event published by the Finish button on the SetupCompleteError dialog and (for silent installations) I have scheduled it with number -3 in the InstallExecuteSequence.
Maybe I should have run MsiGetLastErrorRecord at a different place, but I do not know where to put it. As far as I see, there is nothing like an "OnError" event handler, is there?
Best regards
Matthias
Posted 06 August 2009 - 12:27
MsiGetLastErrorRecord returns a record with information about the last failed API call. For instance, when you call MsiSetFeatureState for a non-existing feature, it returns an error code. To get more information about the error, you can call MsiGetLastErrorRecord.
This is different from the reason why the installation is failing. Say you have a setup with a launch condition. You install on a computer, and that condition is not met, so the installation fails. But the launch conditions were processed correctly, therefore MsiGetLastErrorRecord is empty.
Posted 06 August 2009 - 13:08
Thank you, I am starting to understand it. So my issue moves a bit: is there a "safe" way to extract the reason why the installatoin is failing? As of now, I do not see one.
