Hi newsgroup,
I'm still working with InstallShield Professional 6.1 German and am missing the feature to grant write access to a folder by script. I think I've investigated InstallShield 6.1 to such an extent that I can say it really doesn't have that feature.
So my question is: Which version of InstallShield is capable of setting access rights to a folder? I'd love to update to a current InstallShield version, but want to make sure that this feature is at least in this version.
Regards,
Frank
Grant write access to folder
schoeneichebb
, Dec 05 2008 10:31
Posted 05 December 2008 - 13:51
Probier doch mal ein LaunchApplication mit cacls (oder ggf. icacls unter Vista).
Bei icacls beachten, dass vorher mit ChangeDirectory in den uebergeordneten Ordner gewechselt werden muss, weil icacls nicht mit Gaensefuesschen bei langen Dateinamen umgehen kann. Darum muss man auch LaunchApplication nehmen, LaunchAppAndWait setzt das CurrentDir naemlich selbst. Ob das bei cacls auch so ist, weiss ich nicht, wir setzen spezielle Zugriffsrechte nur unter Vista. Allerdings gibt es derzeit nicht nachvollziehbare Umstaende, unter denen die Zugriffsrechte danach manchmal trotzdem nicht stimmen.
Posted 05 December 2008 - 14:48
Is there really no inherent script method to accomplish this? Not even with the
latest InstallShield version? I mean CreateDir() is for creating folders and ... is for setting folder access rights.
Do you mean the notorious "The Permissions on Folder are incorrectly ordered, which may cause some entries to be ineffective"?
I've already come across this, and that exactly is the reason why I'm looking
for a means within InstallShield doing better.
Regards,
Frank
Regards,
Frank
Posted 05 December 2008 - 16:37
| QUOTE (schoeneichebb @ 2008-12-05 14:48) |
| Do you mean the notorious "The Permissions on Folder are incorrectly ordered, which may cause some entries to be ineffective"? I've already come across this, and that exactly is the reason why I'm looking for a means within InstallShield doing better. |
Actually I don't know yet why access rights are not set properly under Vista from time to time as I haven't looked into that problem yet. It just happens
We're using IS2008 and if there is a possibility to change access rights of a folder it is not obvious enough for me as I didn't find it which is why we're using command line. But setup has not the highest priority here so we don't spend much time to find the best solution. We just try to find something that works somehow (at least in a way not damaging user's systems...). Thus there may be quite a few things in InstallShield I'm completely unaware of.
Btw.: If you really want to upgrade to a current IS version: We had a rather complex setup with dozens of components and I ended up writing the whole thing again after upgrading from IS6.5 to IS12 because the import output was unusable. It's not difficult, just boring and unnerving if there are a lot of components. At least relative path support is better than in IS6.5 which was quite a relief.
Posted 12 December 2008 - 13:13
As far as I know there's no built-in InstallScript function for that purpose.
