Hi
My project has consists of 4 Features all of which you can select or deselect to install in the standard way using the Custom Setup dialog.
If I install 1 or more of the features and then run the setup again then I get the option to Modify, Repair or Remove. This is as it should be.
If I select Modify I can install any of the Features that are not currently installed, that works fine.
If however I select to uninstall an installed Feature (by marking it with the red X) then when I press the Next button nothing happens. The button presses but the next dialog is not displayed and nothing is uninstalled. I have to click Back or Cancel to escape from the screen.
Any help much appreciated.
Modify Mode Problem
Seany
, Jun 15 2010 17:28
Posted 16 June 2010 - 11:52
Double check the condition on the evants of the Next button. Maybe a log will help to see why no action fires. My guess is that all conditions evaluate to false.
Posted 16 June 2010 - 12:03
Thankyou, I'm sure you are correct and I have messed up my conditions for the Next button.
