Does anybody know if it is possible to edit the text on the SdExceptions dialog? Currently when a read only file is discovered a message pops up along the lines of "....To perform the file operation. click the Yes button: otherwise. click No.".
Our testing team have said that some of the full stops "." should be commas "," but I can't see how to change this.
Puntuation error in SdExceptions dialog
Andy York
, Jan 13 2003 11:40
Posted 13 January 2003 - 16:06
I've done QA and still do from time to time, so tell your testing team that's pretty picky and that there are better ways for them to spend their time.
In any case, simply add that event through IS's drop-down lists, specifically Miscellaneous | File Read Only, and override the default code to whatever your heart desires.
I personally despise that message and don't need it to hang our installs, so I just do return ERR_YES; every time so that read-only files are always overwritten or removed.
Posted 13 January 2003 - 16:11
Well I though lost my original post to the bit bucket, but I guess not, so never mind this reply.
