I inherited an MSI install project (MSVS 2010 VDPROJ). It has normal stuff, DLL's, EXE's, some data files, a few COM registry tasks, 2 shortcuts, and a few parent folders, each with a relatively simple subfolder hierarchy. Install works fine and the app works fine. (Note that the install is done with msiexec.exe + a few command line parameters to set custom properties.) But in running the actual app, some additional/new data files are created and maybe an extra subfolder or 2, all within the defined folders created during the install. I find that these new files/folders are not removed during an uninstall. Is there some secret flag/setting in a VDPROJ that I need to set so that ~everything~ is removed? (I have access to the complete VDPROJ set of files, properties, etc.) I don't want to have to resort to using ORCA to "fix" the MSI directly. Thanks for any help.
Uninstall: New files/folders created by an app aren't deleted
mal100
, Oct 19 2018 01:46
Posted 29 October 2018 - 16:42
Files that the application creates after installation are considered user data (e.g. documents) and not deleted by default. You need to populate the RemoveFile table in the MSI or use a custom action to delete the user generated files.
