I am using Orca to merge an MSM into an MSI database.
Within the MSM, I have to use the ModuleSubstitution table in order to use properties from the "base" MSI in conditions within the module. There are no entries in the ModuleConfiguration table.
When I do the merge, the ModuleSubstitution entries are correctly used to substitute the declared table fields.
But the Merge Module components are not linked to a feature any more - there are no "additional" entries in the FeatureComponents table!
As soon as I remove all ModuleSubstitution entries, the FeatureComponents table is filled again.
I suppose this is a bug...
Any ideas how to work around this?
BTW: I am using Orca 3.1.4000.2049, msiexec 3.01.4001.5512
Best regards
Matthias
Edited by Matthias1967, 05 May 2009 - 08:48.
