Hello-
I need to know if there is a way to automatically log on to a machine after a reboot?
I would like to log on to all workstations that run my installation as administrator (the password is the same for all machines) after the machine reboots. I would like the log on to be as silent as possible.
Any suggestions would be greatly appreciated?
Thanks-
Thomas
Log On After Reboot
tlukareski
, May 07 2002 17:51
Posted 08 May 2002 - 13:24
Thomas
There sure is, I use it quite often. The first thing I do is Get the users system login id and password, then update the registry entry. I eventually will reset the entry after the installation has completed(optional). The code I use is below.
Best of luck
Marie
Best of luck
Marie
| Code Sample |
Dlg_SysLogin: szTitle = "System Login"; szMsg = "Please enter the system password for " + szCurrentUser + "."; svEdit1= szCurrentUser; nResult=SdShowDlgEdit2 ( szTitle, szMsg, "UserName", "Password", svEdit1, svEdit2 ); Disable(BACKBUTTON); if(nResult=CANCEL) then bInstallAborted=TRUE; Disable(STATUSEX); Disable(DIALOGCACHE); bInstallAborted=TRUE; ConfirmCancel(); elseif(nResult = BACK) then goto Dlg_SetupType; else Disable(LOGGING); szAutoID = svEdit1; if(svEdit1 = "") then MessageBox("User must enter System Login, this field cannot be left blank!",WARNING); szAutoID= ""; goto Dlg_SysLogin; endif; szAutoPwd = svEdit2; //create tge registry entry: RegDBSetDefaultRoot( HKEY_LOCAL_MACHINE ); szKey = "SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\WinLogon"; nRegType = REGDB_STRING; nResult = RegDBSetKeyValueEx(szKey, "AutoAdminLogon", nRegType, "1", nvSize); nResult = RegDBSetKeyValueEx(szKey, "DefaultPassword", nRegType, svEdit2,nvSize); ********************************************** OnEnd() //delete/reset the autologin (optional) RegDBSetDefaultRoot( HKEY_LOCAL_MACHINE ); nRegType = REGDB_STRING; szKey = "SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\WinLogon"; nResult = RegDBSetKeyValueEx(szKey, "AutoAdminLogon", nRegType, "0", nvSize); nResult =RegDBDeleteValue(szKey, "DefaultPassword"); |
Marie Tupps
