I have the OfficeJet 5610 Printer application to package for Vista Plat form.After installation of application its putting many msi(which i have observed from eventvwr) and unable to find in temp folder. Same time i have treid with silent options but unable to find the correct solution to package. Kindly suggest possilbe thing to package the application
vinod.mnit2004
, Jan 28 2010 12:20
Posted 28 January 2010 - 12:34
- This should be in the 'General MSI' forum
- Many set-up stubs now extract their MSIs to a folder in the '%USERPROFILE%\Application Data' structure. Take a look there. As usual, ProcMon will show you EXACTLY which path is being used. I will repeat: you cannot realistically do this job without ProcMon or something similar. You will spend WEEKS tracking down problems without it.
Posted 28 January 2010 - 16:56
| - This should be in the 'General MSI' forum |
Moved.
