IS 6.31
Has anyone tried installing an app where the installation adds an entry to the Scheduler utility for Windows?
We'd like to automate the installation & execution for a particular application as much as possible so we'd like to add an entry for the app so that it will run without the user having to set things up.
Any advice here would be most appreciated.
Regards,
Ray Gonzales
Adding the installed app to MS Scheduler
Ray Gonzales
, Aug 27 2002 16:08
Posted 25 September 2002 - 09:01
This is done easily. First you should create a silent setup for your installation, if you dont know how please refer to the manual. Then just run it as you planned.
Posted 25 September 2002 - 14:34
vuttex: I guessing he'll also need some additional information on how to actually add his setup to the Scheduler utility through InstallScript code.
