We have some applications installed via MSI 2.0 and whenever we run the same version MSI setup.exe again we get the repair/remove dialog. This is something management here does not wish so is there a way to suppress this dialog?
Suppress repair dialog
Jim Bassett
, Jan 24 2005 16:31
Posted 25 January 2005 - 14:59
You can remove the dialog from the package. But your setup will still enter maintenance mode if you re-run it after it has been installed.
