Hi
I have setup with 2 languages and during installation I see language selection dialog.
It is good when setup is run in normal mode, but I have also my silent mode without iss file - I add parameter to my setup.
So during silent mode I don't want to see language selection dialog.
Can I hide this dialog some function in script or some parameter to setup?
Greg
Disable language selection dialog?
Greg102
, Jan 27 2006 11:03
Posted 27 January 2006 - 18:19
Isn't there an L parameter to specify the language? (I haven't used IS6 for a long time, maybe that parameter was added in version 7)
Posted 28 January 2006 - 01:37
Yes, you remembered correctly Stefan as there is such a parameter in IS6. Here's a copy of the help on the subject:
| QUOTE (InstallShield Professional 6.3 Help Library) |
| /l<language ID> or -l<language ID> Specifies the language in which the setup runs. <language ID> is a numeric language ID of the form 0xnnnn or simply nnnn. The setup runs in this language regardless of the default setup language specified in the IDE or the default language of the target system. This switch has no effect when the setup is running silently and a Lang key is set in the [Application] section of Setup.iss. Recording a response file (by running Setup.exe with the -r switch) sets the Lang key automatically; for the -l switch to affect a silent setup, this key must be deleted from Setup.iss. |
Posted 01 February 2006 - 12:42
Thank you for answers.
Is it possible to make it in script instead of parameter?
I need to check some registry and than choose language.
Posted 01 February 2006 - 15:23
I don't see a way to do it via script since it's required for proper initialization of the IS setup.
However, you can edit the [Startup] section of Setup.ini and change it to read EnableLangDlg=N to try having InstallShield automatically make that choice for you.
For more information, check out the IS help topic "How InstallShield determines which language the setup should run in".
