How do I elevate custom actions in InstallShield 11 so that they run with administrative privilages under the current user? I have an executable that cannot be run under a System context due to some registry modifications that the program needs to make, but the program must have administrative privilages to execute successfully. Any help is greatly appreciated!
Chayodyn
Elevating a Custom Action
Chayodyn
, May 22 2007 16:26
Posted 23 May 2007 - 12:50
This doesn't quite add up, why do you need admin rights to write to a per user profile?
Posted 23 May 2007 - 19:24
The executable uses information from the HKEY_CURRENT_USER portion of the registry, and attempts to create a file in the Program Files directory. When I attempt to run this in Vista, the OS will not allow the program to execute completely since it needs to write to Program Files.
Posted 24 May 2007 - 02:23
Hope it does not sound rude, but this does not sound like good application design. What is the nature of the file generated - some sort of license file? If so you should consider using the profile folders (allusersprofile or userprofile).
You fall between two chairs here: when a custom action runs elevated there is no user context (no HKCU, no userprofile etc...), when you run as a user there is no elevation. The reason there is no user context when running elevated is because the custom action will run with the localsystem account (which is a special account used by the windows operating system to run services and OS processes).
Edited by Glytzhkof, 24 May 2007 - 02:24.
