Hi
How to differentiate between different editions of Vista in InstallShield Basic MSI Project.
eg. what would be the Install condition if I want to install the software only on Vista Business and Ultimate.
How can we know what edition of Vista is running.
Madhukar
Install condition for Vista Editions
mrgandra
, Nov 29 2006 23:30
Posted 30 November 2006 - 01:07
I don't have Vista, so I can't tell you definitively what the values are, but one thing you can do is use SprintfBox to find out what the values are when run on Vista.
For example:
SprintfBox(MB_OK, "Windows Version Numbers", "OS Major %d, Minor %d, Win Major %d, Minor %d", SYSINFO.nOSMajor, SYSINFO.nOSMinor, SYSINFO.nWinMajor, SYSINFO.nWinMinor);
Put this in a custom action early in a test MSI and run it on the operating system you want to test. That will give you the numbers you need to use in your install conditions.
For example:
Posted 30 November 2006 - 03:03
Hi
Thanks for the reply.
I dont know if this is this is right way to differentiate between different editions of vista.
In Registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ProductOptions
there is key called ProductSuite which can has Terminal Server Personal for Vista Home Basic and Home Premium. For Bista Business, Ultimate and Enterprise it would say Terminal Server.
I dint know how to diffrentiate between the Business, Ultimate and Enterprise. This single piece will help me right now because I only want to know whether it is Home or Other edition.
If any one has any other solution please post it.
Madhukar
Madhukar
