Does anyone have a CA that will stream a bitmap into the Binary table?
I'd rather do it that way so it's self-documenting.
ORCA and Power Editor are too manual; easy to forget to tell my replacement that I did it.
thanks, Rob
Need CA to stream bmp into binary table
rflum
, Feb 27 2002 23:39
Posted 16 April 2002 - 04:25
This reply is abit late. but for reference purposes.
I use this VB code.
(m_View and m_DB and m_Installer previously defined)
Public Sub InsertBinaryStream(ByVal strStreamName As String, ByVal strImportPath As String)
Dim objRecord As WindowsInstaller.Record
Dim strSQL As String
strSQL = "SELECT `Name`,`Data` FROM Binary"
Set m_View = m_DB.OpenView(strSQL)
Set objRecord = m_Installer.CreateRecord(2)
objRecord.StringData(1) = strStreamName
Call m_View.Execute(objRecord)
Call objRecord.SetStream(2, strImportPath)
Call m_View.Modify(msiViewModifyAssign, objRecord)
m_View.Close
End Sub
I use this VB code.
m_View.Close
End Sub
