Hi i'm trying to install the mfc71* files into [INSTALLDIR]\bin but the workaround in the readme only seems to work for installing to [INSTALLDIR]
Is there a way of getting around this? I don't want to assign TARGETDIR to [INSTALLDIR]\bin because I suspect that this might change the installdir path.
Has anyone run into this problem?
thx..
t
Another vc++ .net merge modules bug?
tl0
, Nov 04 2003 21:54
Posted 05 November 2003 - 10:36
You will have to add a Directory table entry for bin as sunfolder of INSTALLDIR. Call it something like BINDIR and use that as destination for the merge module (in whichever way you work around the problem - what is written in which readme?)
