I am trying to do the following:
1. Determine if a certain component (not product!) is already installed.
2. If it is installed, then at the beginning of the setup, I wish to set a property to X, otherwise set it to Y (X and Y are example values).
3. Also, there is a possibility that the above property should be set to a value that resides in the registry (a value that is not constant like X or Y). The registry path is known, of course.
I don't know where exactly to begin. Any suggestions?
