dears:
HI,I met a problem with install to vista.
Every time i merge vs2005's libary(mfc 8.0,atl 8.0,crt 8.0)in my installer,it will
be freezen more than 5 minutes at InstallFinalize.
log issue is
MSI (s) (F4:BC) [16:04:31:562]: Product: MYAP. The application tried to modify a protected Windows registry key \CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32.
MSI (s) (F4:BC) [16:04:31:562]: Product: MYAP. The application tried to modify a protected Windows registry key \CLSID\{00020420-0000-0000-C000-000000000046}.
. ...all the same issue
and I find if i remove those in the ISMergeModule table ,it will install and uninstall well .If i add one of them to ISMergeModule table,installer freezes at the same place .
Would anyone give me suggestions to solve this problem.
In the ISMergeModule table is
ATL.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E 0 Visual C++ 8.0 ATL (x86) WinSXS MSM Beta2
CRT.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E 0 Visual C++ 8.0 CRT (x86) WinSXS MSM Beta2
MFC.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E 0 Visual C++ 8.0 MFC (x86) WinSXS MSM Beta2
InstallFinalize error
mintychang
, Jun 19 2006 08:26
Posted 20 June 2006 - 10:16
I guess the resources in this merge module should not be installed on Vista but the module may not have the proper conditions to prevent it from trying. You could modify the module, or contact Microsoft for an updated module.
Posted 23 June 2006 - 04:14
Thank you,Stefan. I packet a simple installer with IS11.5 only a file inside.And It is the same. Perhaps,I should try IS12 or install Vcredist_x86.exe silently.Or Windows Installer 4.0 is a good ideas?
