I've got some problems with my Installshield project and I hope you can help me..
Problem 1:
I use skins, and the logo is in the same place as the computer image. I already got rid of the computer image using
DialogSetInfo (DLG_INFO_ALTIMAGE, "", TRUE);
but it doesn't work when the installer is preparing setup.
Also I need to remove the text in the left top. ("Preparing Setup: Please wait while the Installshield wizard prepares the setup") (See images)
Problem 2:
I want the user to ask if they would like to restart the computer, but I dunno what and where I need to put the InstallScript.
I tried this but it doesn't work.
// Show final dialog.
SdFinishReboot( SdLoadString(IFX_SDFINISH_REMOVE_TITLE), SdLoadString(IFX_SDFINISH_REMOVE_MSG2), SYS_BOOTMACHINE, "", 0 );
Problem 3:
When the user is installing our product, we'd like to show some billboards but I can't enable the small statusex window (so it won't block the billboard images) which should be placed in the right bottom corner. How do I enable the small status ex window? And where should I place it?
Problem 4:
I would like to install the Macromedia Flash OCX on the user computer, so that one of our Delphi programs can use SWF files. Is a Flash MX 2004 redist available to insert in the installer, of which files / registery do I need install on the users computer
Hope you could help.
Edited by Morph, 28 June 2004 - 19:47.
