Using Basic MSI in DevStudio 9
How does WI tell that an install needs to reboot? Does it look only at the ReplacedFilesInUse property?
I need to schedule one of two custom actions depending on whether my install needs to be rebooted. Will it be enough to condition one as "ReplacedFilesInUse" and the other as "Not ReplacedFilesInUse"?
Properties Indicating Reboot
KathyMorey
, Aug 30 2005 21:01
Posted 30 August 2005 - 21:01
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 30 August 2005 - 22:34
Hello,
There is a property in Windows Installer called REBOOT, whose value can help you evaluate whether or not to kick off either custom action.
http://msdn.microsof...etup/reboot.asp
Cheers,
Bryan Garretson
DesktopStandard Corp.
BGarretson@desktopstandard.com
Cheers,
Bryan Garretson
Posted 31 August 2005 - 13:52
My understanding of the REBOOT property is that it tells the installer whether or not to suppress a reboot if it is needed, but it doesn't help you determine whether a reboot is needed. Am I understanding that wrong?
What I need to know is how to tell if a reboot is needed - that is, how does the installer know to show the "do you want to reboot" screen instead of the "install completed" screen.
Kathy Morey
Posted 01 September 2005 - 16:52
I too am looking for a solution. I was supplied this:
http://support.insta...ticleid=Q105762
But what I need to do is test a property in a UI control condition (I don't want to display the 'Launch Application' checkbox at the end of the install if a reboot is required).
Where would be the best place to call this script so that it could set a property using MsiSetProperty() which I can test later?
