Hi All,
One of my client is getting an error while installing ISPRO exe.
The error represents The system cannot find the path specified.
But the file represents to pftw1.pkg .
I had created the setup.exe using SingleDiskImage and not PackageFor the web type.
My question is why this error occur in such type.
Kindly clarify me, also this happened only in selective machine and not in all machines.
thanks,
prasanna N
error while extracting files
prasankn
, Jul 27 2006 04:02
Posted 30 July 2006 - 01:08
Well a single disk image is essentially doing a PackageForTheWeb setup in the background, so I would try unpacking it on a separate machine and then running a copy of that manually on the problematic box to see if the error goes away.
My guess is there's a problem with the system TEMP variable or something to that affect.
